Author Topic: Griff 1.4LX 1999  (Read 24010 times)
Offline Griff
  • WRC Contender
  • Cooler than a lesbian genderfluid penguin
    • richardwho
Griff 1.4LX 1999
« on: September 15, 2009, 12:28:40 am »
I bought my silver Xsara 1.4 LX from a neighbour in January 2009 with 96,890 on the clock, becomming the fourth owner of 'Dougal'.
Dougal was built at Rennes la Janais factory in France on 25th November 1998, first registered by Bristol Street Motors, Nottingham, on the 18th March 1999 and would have cost in the region of ?12,630 new. When I bought the car it came with a full service history.
Vehicle family    XSARA
AS RPO No    08052 CJ 2 0172
Guarantee Start Date    01/01/1990
Engine serial number    10 FS7U 2579585
Gearbox serial number    20 CE42 0065462
OPB    N01I
NRE    e2*93/81*0104*02
General information
PRODUCT TYPE    CAR
COMMERCIAL MARQUE/COMPONENT TYPE    CITROEN
VEHICLE FAMILY    XSARA
SILHOUETTE    5 DOOR SALOON
TRIM LEVEL    LEVEL X P
ENGINE    INJECTION TU3JP
TRANSMISSION    BVM5
INTERIOR TRIM TYPE    PEPITA CLOTH "EK"
UPHOLSTERY COLOUR    FZ
GEARBOX (CHARACTERISTICS)    UP-RATED BVM/MA
ENGINE (TYPE)    TU/TUD
OTHER BADGE    1,4 I
OTHER BADGE, " MISC. "    WITHOUT FULLER BADGE
BADGE    XSARA BADGE
Vehicle characteristics
STEERING    POWER STEERING
SPEEDOMETER DRIVE    TACHO TORQUE 21X18
Fuel supply-Engine
FUEL SUPPLY    INJECTION PRIM
CYLINDER BLOCK (MATERIAL)    CRANKCASE ALUMINIUM
FUEL    LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE)    EEC 95 DEPOLL (ENGINE)
PRE-FILTER    ASSEMBLY WITHOUT PRE-FILTER
OIL COOLER    WITHOUT OIL-WATER DISTR CHAMB
LPG FUEL TANK    WITHOUT LPG TANK
COOLING MOTOR    RADIATOR 17 DM2 (23 TR)
CRANKCASE GAS CIRCUIT HEATING    W/O HEATER CASING GAS CIRCUIT
VEHICLE TECHNICAL DEPOLLUTION    L3 VEHICLE TECHNICAL DEPOLLUTION
FAN    1 FAN 1 SPEED LOWER 120W
FUEL VAPOUR RETRIEVAL    NON CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT    MOUNTING MAGNETI MARELLI
Gearbox-Driveshafts
TRANSMISSION    BVM5
FINAL DRIVE RATIO    REAR AXLE HYPOID GEARSET 14 X 60
WHEEL STYLE    14 INCH STEEL WHEEL
SEAL, WHEEL END    WHEEL-SIDE JOINT AC2000I
SEAL, DIFFERENTIAL END    AXLE-SIDE JOINT GI2000I
DIFFERENTIAL (GEARBOX)    STD GEARBOX DIFF
TYRE (SIZE, TYPE)    185X65X14 T TYRES
DRIVING WHEELS    2 DRIVEN WHEELS
WHEELS FITTED    5,5" RIM ROAD WHEELS
WHEEL (TYPE)    STEEL WHEELS
GEARBOX TYPE    MA
Suspension-Steering-Brakes
ABS    W/O ABS BRAKES
REAR ANTI-ROLL BAR    REAR ANTI-ROLL BAR DIAM 20
FRONT ANTI-ROLL BAR    FRONT ANTI-ROLL BAR DIAM 18
SERVICE BRAKE    WITH INTEGRATED COMPENSATOR
BRAKE TYPE    NON-VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION    NORMAL SUSPENSION
Bodywork-Exterior fittings
TOWBAR    WITHOUT TOWBAR
HORNS    HORN STANDARD
REAR SPOILER    ASSEMBLY WITHOUT REAR SPOILER
SIDE MOULDINGS (TYPE)    LATERAL PROTECTOR MASS TINTED
WHEEL EMBELLISHER (STYLE)    EMBRUN STYLE 7 HOLES 14 INCHES
EXT. REARVIEW MIRROR COMP. FUNCTION    EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
ENGINE BAY SOUNDPROOFING    BULKHEAD + BONNET SOUND-PROOFING
WINDSCREEN WIPER    INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
HEADLAMP WIPER    W/O HEADLAMP WIPER
FRONT PANEL BLANK    LARGE AIR ENTRANCE FRONT BUMPER PLUG
BUMPER    TWO TONE BUMPER SMALL SPOILER
LUGGAGE RACK    WITHOUT ROOF BARS
FRONT FOGLAMP    FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC)    SINGLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)    NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)    PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
EXTERIOR ACCESSORIES    EXT HANDLE UNCOLOURED+RRVIEWMIRROR BODY COLOUR
SUN ROOF    SUNROOF ELECTRIC CONTROL
GLASS (APPEARANCE)    TINTED
Interior fittings
ANTI-THEFT ALARM    WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT    WITHOUT REAR HEADREST
FRONT HEAD RESTRAINT    FRONT HEADREST ADJUSTABLE
REAR SEAT    INTEGRAL FOLD BACK BENCH SEAT
REAR SEAT ARMREST    WITHOUT REAR ARMREST
FRONT SEATBELT    PYROTECHNIC SEAT BELT WITH ALARM
SPEED GRADUATIONS    GRADUATION MPH
TACHOMETER    REV COUNTER WITH NEEDLE
RADIO EQUIPMENT    FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITION    RIGHT HAND DRIVE
REMOTE CONTROL    REMOTE CONTROL ASSEMBLY
MISC. INT. LAMPS    MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS)    220 KM/H OR 140 MPH GRADUATION GREY/BLUE DIAL
TACHOMETER (SIGNAL CONNECTION)    REV COUNTER CALC
LOUDSPEAKER    MOUNTING 4 FRONT LOUDSPEAKERS + 2 REAR
RADIO CONTROLS    REMOTE RADIO CONTROL
FRONT PASSENGER SEAT HEIGHT CONTROL    WITHOUT SPACER PASSENGER SIDE
DRIVER SEAT CONTROL    DRIVERS FRT SEAT MANUAL CNTROL
DRIVER SEAT ADJUSTMENT    WITHOUT DRIVER'S LUMBER AND SIDE SUPPORTS
FRONT PASSENGER SEAT ADJUSTMENT    WITHOUT PASSENGER LATERAL BEARING
COMPACT DISC    WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM    WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT    MAN CTRL REAR WINDOW LIFTER
DRIVER'S WINDOW LIFT    ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER'S WINDOW LIFT    ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK    NUMERIC CLOCK
COURTESY MIRROR    DRIVER+PASSENGER OCCULTABLE W/O LIGHTING
OIL GAUGE    OIL LEVEL WARNING INDICATOR
HEATING ELEMENT    NON HEATED SEAT
FRONT LATERAL AIRBAG    LATERAL AIR BAG
REAR PASSENGER PROTECTION    W/O RR PASSENGER PROTECTION
PASSENGER AIRBAG    PASSENGER AIRBAG
COURTESY LAMP    FR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SEAT GUARD    WITHOUT SEPARATION GRILLE
STORAGE (DRIVING POSITION)    INJECTED LOWER GLOVE BOX
RADIO RECEIVER    PERFORMANCE 4 RDS RADIO
REFRIGERATION    WITHOUT AIR CONDITIONING
DRIVER'S SEAT HEIGHT CONTROL    WITHOUT HEIGHT ADJ DRIVER SIDE
STORAGE (OTHERS)    CONSOLE RR GLOVE-BOX W/O LID
CARPET COVER    W/O CARPETMAT
DRIVER AIRBAG    DRIVERS AIR BAG
LOAD SPACE STORAGE    W/O BOOT TIDY
CARPET    DILOURS CARPET F330
WEAR INDICATOR    W/O BRAKE WEAR WARNING LIGHT
EXTERIOR TEMPERATURE (SCALE)    WITHOUT EXTERIOR TEMPERATURE GAUGE
SWITCH    ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR    WATER TEMP INDIC +RED TELLTALE
LOCKING CONTROL    CENTRAL DEAD LOCKING
STEERING WHEEL    RUBBER STEERING WHEEL
Electrical
ALTERNATOR    ALTERNATOR 70 AMP
HORNS    HORN STANDARD
BATTERY    BATTERY L1 200
STARTER MOTOR    CLASS 1 STARTER MOTOR
SPECIAL LIGHTING    WITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCY    433 92 MHZ HETERODYNE
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION    STANDARD
ATMOSPHERIC CONDITIONS    NORMAL ATMOSPHERE
WEAPON MOUNTING POINTS    WITHOUT ARMAMENTS ADAPTATION
RADIO HEADPHONE SOCKET    WITH ACCESSORIES SOCKET
« Last Edit: January 13, 2012, 07:51:31 pm by Griff »
May contain 35 other Citroen Xsara's, a Xantia, and some Pug 306 parts. May even have new parts fitted.
Offline aussiexsara
  • WRC Contender
  • xsara tragic
Re: Griff 1.4LX 1999
« Reply #1 on: September 15, 2009, 04:57:41 am »
any pics?? :)
02 VTS ph2 Full WRC Rallysprint Replica v1 and wrc pretender
Offline cliff7110
« Reply #2 on: September 15, 2009, 03:38:57 pm »
nice to know. O0
Citroen Xsara VTS - Koni SSK's, Csaba strut brace, Hybrid rear anti roll bar, HIDS, Miltek cat back 100mm exhaust, Pro races 1.2s, toyo T1R,s braided hoses
« Reply #3 on: September 15, 2009, 07:18:29 pm »
wanna borrow this?
 ;D
Offline aussiexsara
  • WRC Contender
  • xsara tragic
« Reply #4 on: September 15, 2009, 10:58:39 pm »
yeah right - he's probably out banging something in the shed :2funny:
Offline Griff
  • WRC Contender
    • richardwho
« Reply #5 on: September 26, 2009, 02:54:56 pm »
Photographs of 'Dougal' taken in Edmondthorpe, Leicestershire, July 2009
« Last Edit: September 27, 2009, 12:06:54 am by Griff »
Offline Griff
  • WRC Contender
    • richardwho
« Reply #6 on: September 26, 2009, 03:04:49 pm »
By this time I had replaced the door mirror, replaced the missing wheel trim, Xenon headlights, 100k service, new brake shoes, alloy wheels (from a 1998 VTR in a scrap yard just outside Norwich), new cat, CD boot changer (yes I still play tapes, and listen to Test Match Special on Radio 4 long wave) Xsara car mats, and general tidying up. Next mission - replace the leaking hatchback rubber, then MOT in November.
« Last Edit: September 26, 2009, 11:58:04 pm by Griff »
Offline Griff
  • WRC Contender
    • richardwho
« Reply #7 on: September 26, 2009, 03:11:46 pm »
Filled up with Shell V-power (other super unleaded are avalable) and took it for a run on part of the A6 (dual carrageway) about 5am this morning. I was actually checking to make sure I was happy with a new Tyre. After overtaking a car doing the otherside of 60 (honest) he then wants to race - WHY. I was racing myself (Dougal's best performance yet) nobody else was invited. Anyway I hope the speed camera got him.
Offline john boy
  • Global Moderator
  • ph 1 sx 1.8 16v ph1 lx 1.9d
« Reply #8 on: September 26, 2009, 09:25:53 pm »
looks quite a clean one mate  O0
Offline aussiexsara
  • WRC Contender
  • xsara tragic
« Reply #9 on: September 27, 2009, 06:56:07 am »
any plans for her??
Offline Griff
  • WRC Contender
    • richardwho
« Reply #10 on: September 27, 2009, 09:27:23 pm »
Oh yes I have a plan or two, but the more and more I think about it, I realise that I must be entering middle age. I want to get hold of a new set of seats.  I need a car with a split back seat as It is rather difficult to transport the family and a Tuba (musical instrument). I think the boot was designed just NOT to hold my instrument. (your imagination can provide the obsenity to French design). I can only transport the Tuba on the back seat, hence then haven't got the room for my partner (Vectra owner) and daughter. I would like a nice leather interior, shades of driving around in a Wolseley 16/60, but with side air bags, so I am watching the usual places (including ebay and a couple of car breakers I know) to see what turns up.
No I haven't any plans for a body kit et cetera, as with the Wolseley all we ever did with it was to try and get it back to an original condition and keep it looking that way. I think though a K+N air filter could appear on a christmas / birthday list.
When I bought Dougal I originally planned to keep him for a couple of years, then move on... now I'm not so sure. Well my father bought the Wolseley in 1973 (just before I was born) and we still have it, so I think is genetic. He used to tell me If you have a good car, why get rid of it. I think that now I would rather make him to be how I need a car, than go out and buy another.
Took Dougal to Ely and back today, as I promised the family a day out. Three adults, one child, and he could still hold his own, comfortably managing 70mph on the dual carrageway through Peterborough. - Cheers Dougal.
Anyway I'n not critising French Design, a car like the Wolseley 16/60 (yes I will put some pictures up on the web page of it), and the Tuba wouldn't fit in the boot either. It had to go on the back seat as well but without rear seatbelts allowed you to sit infront of it.
« Last Edit: September 27, 2009, 09:37:22 pm by Griff »
Offline aussiexsara
  • WRC Contender
  • xsara tragic
« Reply #11 on: September 28, 2009, 12:49:09 am »
very dry :2funny: :2funny: O0
Keep blowin your horn :2funny:
Offline Griff
  • WRC Contender
    • richardwho
« Reply #12 on: September 29, 2009, 07:00:27 pm »
Finally, I have a car that DOES NOT LEAK. Since I have owned Dougal, rain get's in around the hatchback, leaks into the boot and back seat area. Summoned up the courage to visit my local Cirtroen dealer to buy a new weatherstrip (after of course checking the rear lights et cetera were screwed in properly) Just picked up the NEW strip, and fitted it. Cheched it with the hose, and at last no water gets into the boot area. Next part ordered - new engine breather pipe.
Got a few other quotes for other parts - out of interest. The two front air bags alone cost more than I paid for the car.
Offline Griff
  • WRC Contender
    • richardwho
« Reply #13 on: October 01, 2009, 09:06:40 pm »
New engine breather pipe fitted today - in the forecourt of my local Citroen dealer.
A few pictures of Dougal's stable mate - a 1966 Wolseley 16/60
This picture was taken in 1978 (yes that is me in the picture, and no I no longer wear red socks or sandles)
« Last Edit: October 01, 2009, 09:08:41 pm by Griff »
Offline Griff
  • WRC Contender
    • richardwho
« Reply #14 on: October 01, 2009, 09:10:50 pm »
More recent pictures of the Wolseley. By this time after a couple of re-spray's it's Maroon and Old English White have been changed to a metallic Maroon and White. Yes it is possible to start this car with a starting handle, which also doubles up as the handle to release the spare wheel undercarrage. Enjoy.
« Last Edit: October 01, 2009, 10:53:24 pm by Griff »
