Author Topic: Comms 2000 Unit  (Read 3265 times)
Offline xsaraiihdi
Comms 2000 Unit
« on: May 11, 2009, 11:00:51 am »
Hi All
I have been reading here about verious problems with lights and flashing dipped beam warning light. I beleave these problems are down to the Comms 2000 Unit or indicator and light stalk part of this unit.
My own Xsara has a few faults whereby I can be driving down the road and the lights will come on and the dipped beam warning light flashes, on their own if I apply gentle downward pressure on the indicator stalk they go out. The second problem is if I indicate to turn right the headlights come on and the dipped beam warning light flashes. I shall be investegating these problems once I have fitted a replacement rear beam axle with coming weekend.
I beleave thses Comms 2000 unit can very in price from ?175.00 to ?250.00 + vat dependant on functions.
I will keep you posted.
Offline xsarastan
  • 1999 VTS, 2001 VTS & 2002 HDI ESTATE
Re: Comms 2000 Unit
« Reply #1 on: May 12, 2009, 03:22:10 am »
plus coding  ;)
Vehicle de Turismo Sport
Re: Comms 2000 Unit
« Reply #2 on: May 12, 2009, 09:16:12 pm »
plus coding  ;)
They only need programed if the car is fitted with ESP as the steering wheel angle sensor needs to be calibrated. Any without ESP just plug straight in.
jamjar1383
  • Guest
Re: Comms 2000 Unit
« Reply #3 on: June 22, 2009, 05:45:55 pm »
hi wheeler
im wondering if you have had any joy finding out more about this fault with the comms 2000 unit, mine seems to be getting worse the lights coming on and the flashing warning light has been happing more in the warmer weeks.
Re: Comms 2000 Unit
« Reply #4 on: June 22, 2009, 07:14:47 pm »
I've not been trying to find out any more because i dont have any problem  :)
It's most likely the com2000 unit itself though if you can make the lights go off again by wiggling the switch,  You just need to replace the full unit
