Author Topic: wheel hub snapped  (Read 593 times)
Offline Alastairh
Re: wheel hub snapped
« Reply #15 on: May 04, 2012, 07:26:47 pm »
You need to know where ever your ball joint is 16 or 18mm.
I should have both types. £30 delivered.
Offline raineuk
« Reply #16 on: May 04, 2012, 08:05:12 pm »
Excuse me for being slightly dense but what is 16 or 18mm and how do I measure the said measurements.
Offline argoose
  • never stroke another mans rhubarb!
« Reply #17 on: May 04, 2012, 08:20:03 pm »
its the diameter of the bottom ball joint pin hole, but yours has sheared so you'll have to find out where on the pin to measure, as it's tapered I should imagine at the thickest part, hope someone can confirm or correct for me  :coolsmiley:
Offline welshpug
« Reply #18 on: May 04, 2012, 11:26:23 pm »
its not tapered
Offline Griff
  • WRC Contender
  • Cooler than a lesbian genderfluid penguin
    • richardwho
« Reply #19 on: May 05, 2012, 07:54:36 am »
Not a bad price if it includes postage.
Nat's came off when she had the Corsa.
Mechanic put a 'new' hub on from the scrap yard.
May contain 35 other Citroen Xsara's, a Xantia, and some Pug 306 parts. May even have new parts fitted.
Offline raineuk
« Reply #20 on: May 05, 2012, 03:29:23 pm »
I measured the diameter and its 18mm I've sent you a PM
Update: I've just ordered a new ball joint from p4l and their ball joints are 16mm
« Last Edit: May 05, 2012, 07:01:46 pm by raineuk »
Offline mcjordi
  • I Poked Ya Mam
« Reply #21 on: May 05, 2012, 05:37:51 pm »
 :o :o
bloody hell..
« Reply #22 on: May 05, 2012, 08:18:33 pm »
That must have been taking some grief - any sign of hammer marks on there?
Offline Testor VTS
« Reply #23 on: May 05, 2012, 08:29:56 pm »
"How hard can it be?"
Offline raineuk
« Reply #24 on: May 05, 2012, 09:44:54 pm »
No hammer marks but the inner edges have scuff marks as though someone had pried it apart to release the ball joint. When the parts are put together the shape is more oval the circular. Also I noticed that the part that broke off 3/4 of one side had rusted, so obviously it had cracked awhile back. Luckily I was only doing 5mph. 10 minutes earlier I was doing 60 on the bypass. I dread to think.
« Reply #25 on: May 06, 2012, 12:01:08 am »
obviously some monkey has hammered a chisel in to remove a balljoint. never a good idea with cast iron.
Offline Testor VTS
« Reply #26 on: May 06, 2012, 08:45:33 am »
« Reply #27 on: May 06, 2012, 12:01:43 pm »
Favourite one years ago on the Morrie Minor and A30/35 was for the single front wishbone bolt to pull out thro' a rusted chassis.
Very common occurrence and hugely entertaining - unless the car in question is sliding across the road straight at you at 30mph.   :o
Fortunately, the chassis caught in a handly drain grating and stopped rather abruptly.  :2funny:
Offline chrispyvtr
  • KEEP IT SIMPLES
« Reply #28 on: May 08, 2012, 06:51:05 pm »
Try www.frenchspares.com 01777817070 they can dispatch the same day
Low N Slow
Offline welshpug
« Reply #29 on: May 08, 2012, 11:27:22 pm »
surprisingly common especially if some eejit has fitted a 16mm BJ and just tightened the bolt up tight, instead of 23 lbft.
