Make sure you aren't over-tightening the slider bolts, I made that mistake on my ZX when I replaced both rear calipers. I managed to over tighten the bolts and I cause the sliders to bulge, if only slightly, but I spent a very long time trying to work out why my back brakes were binding and I only realized when I removed the rear disc and tried to move the caliper on the sliders, now I don't know if this is due to the fact I used fairly cheap ECP calipers, I know the main caliper bodies were original, but the sliders might have been very cheap and nasty (which wouldn't surprise me from ECP).
I fixed this by using a little loctite and not doing the bolts up quite so tight, for me anyway, problem solved.
