Author Topic: people running decats please advise  (Read 649 times)
Offline NickW
« on: January 20, 2012, 07:54:20 am »
hello
im thinking of getting a Decat made up for my phase 2 VTS
im already running a pretty straight throu single longlife exhaust but i cant help thinking that the cat must be restricting it quite a bit also due to lowering my car my cat gets smashed to pieces
so people running decats
did you notice a performance gain by fitting it?
did the exhaust get a lot louder?
Offline welshpug
Re: people running decats please advise
« Reply #1 on: January 20, 2012, 11:31:40 pm »
personally I wouldn't bother, I felt no gain when I decatted mine, in fact more likely a loss of mid range torque.
and of course its illegal now.
removing it will not give additional ground clearance as they do not sit below the level of the sills in my experience, also running that low will render the beautiful handling of the standard chassis useless and wont be able to use the lovely VTS engine.
might as well shop it for a 1.4.
Offline NickW
« Reply #2 on: January 23, 2012, 08:15:17 am »
the cat on my vts sits much, much lower than the sills
also the lowering has made the car handle brilliantly like its on rails with out any body roll
Offline welshpug
« Reply #3 on: January 23, 2012, 12:44:59 pm »
less body roll does not equate to better handling.
if the cat does sit low then its likely to be the wrong one.
Offline NickW
« Reply #4 on: January 23, 2012, 12:59:21 pm »
thanks for your reply welshpool but im pretty sure it is the right cat,  also i have heard of other people saying that there cat hangs pretty low,
Also i bought the car standard and lowered it myself, it handles much better lower thanks
Offline ratboy
  • 20mm lower strutbrace knn induction 17" tsw heats
« Reply #5 on: April 19, 2012, 07:19:07 am »
Mine has 40mm lowering spax springs 215 40 17's standard torsion bar
That defenetly improved the handling due to no body roll
The standard suspension is good but slightly lowered and wider tires was a great investment
I also have a low ish hanging cat but ive had a 6 cat back systems from stupid quick fit b4 the got me a genuin Citroen centre and rear
I catch the cat slightly on the narrow speed bumps
ph1 vts mmmmmmm
Offline xsararacer
    • Marquis Motorsport Ltd.
« Reply #6 on: April 19, 2012, 08:54:59 pm »
Decat does make a difference to engine response, less so to peak power until you start tuning on the intake side.
If it has an engine - drive it!
Discounted Goodridge brakeline kits and Powerflex bushes at www.marquis-motorsport.com!
« Reply #7 on: April 20, 2012, 12:16:21 pm »
sorry this is off topic but do you want some GTI6 torsion bars to stiffen the rear up a bit?  :smiley6600:
Offline welshpug
« Reply #8 on: April 20, 2012, 06:50:13 pm »
his sig says he has a vts, i.e 21mm bars, gti6 are 20mm...
« Reply #9 on: April 21, 2012, 01:12:26 am »
my bad i had 1.8 VTRs on the brain  :-[
