Author Topic: Xsara 04 HDI 90  (Read 2212 times)
Offline Testor VTS
Re: Xsara 04 HDI 90
« Reply #15 on: October 18, 2011, 11:47:41 am »
+10?....   there was -4? in the morning here... ;D
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #16 on: October 18, 2011, 01:01:39 pm »
Hey, we're not that used to cold weather, just miserable weather  ;)
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #17 on: October 19, 2011, 08:13:50 am »
4C and all started as expected. Just didn't rush it! Phew.
Re: Xsara 04 HDI 90
« Reply #18 on: October 19, 2011, 09:06:19 am »
Your heater plugs probably did flash on just for a moment, but it's easily missed. As you say, just take it a little slower - more haste, less speed.  ;D
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #19 on: October 19, 2011, 09:31:16 am »
Thanks.
I had a look at my stiff accelerator pedal last night and I greased the cable and pedal pivot. I then discovered it was fly by wire. I think the 'pot' in the engine bay is a little stiff in operation. Anyone experienced this before?
As it's al can bus, is there an easy way to add cruise control to this engine?
Re: Xsara 04 HDI 90
« Reply #20 on: October 19, 2011, 10:33:07 am »
I believe it can - ask Tibi - he knows, as that one's cropped up before. On some models you can fit the stalk then activate with Lexia.
Offline Testor VTS
Re: Xsara 04 HDI 90
« Reply #21 on: October 20, 2011, 08:09:30 am »
depends on the phase! if it's a ph.2 without the COM2000 then it'll be a hard task, but if it's a ph.2.5 with a COM2000 stalk then it's a doddle! ;)
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #22 on: October 20, 2011, 08:19:20 am »
I think it's a PH2.5. It's one of the last Xsara's made in '04 afterall.
Do I need the stalk and actuator or just stalk?
Offline Testor VTS
Re: Xsara 04 HDI 90
« Reply #23 on: October 20, 2011, 05:49:10 pm »
which type of stalk do you have from these two below:
1.early type  (ph.1, ph. 1.5, ph.2)
2.later type COM2000 unit (ph. 2.5)
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #24 on: October 21, 2011, 02:50:04 pm »
Comm2000. It also has a stalk for the radio controls on the right.
Ph2.5
Offline Testor VTS
Re: Xsara 04 HDI 90
« Reply #25 on: October 21, 2011, 07:22:54 pm »
then it's easy! just buy the cruise control stalk, push it into it's place and find someone with a Lexia near you and do the necessary settings/codings (dead easy)
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #26 on: October 23, 2011, 11:15:49 am »
Cool  O0
I think the bottom section of the steering column cowl will need modding or changing though as I can't see a slot for it.
Re: Xsara 04 HDI 90
« Reply #27 on: October 23, 2011, 11:51:47 am »
Junior hacksaw strikes again. ;D
Offline Floyd
Re: Xsara 04 HDI 90
« Reply #28 on: October 24, 2011, 12:42:02 pm »
I've seen some stalks for about ?35 delivered. Is this the going rate?  ???
Update on the fuel consupmtion - I managed 511 miles on a tankful and could only squeeze in 45 litres to brim it back up. If I was really brave I think I could get 600 out of a tank barring any hills of course! I make that about 51 mpg's, which is ever so slightly less than previous but then again, my driving hasn't been as gentle and a bit more town/short trip stuff. I must be brave and try a 'drive it normal' tank fulll to see what happens...
« Last Edit: October 24, 2011, 12:46:42 pm by Floyd »
Offline Testor VTS
Re: Xsara 04 HDI 90
« Reply #29 on: October 24, 2011, 06:26:10 pm »
and don't forget it's getting colder, and the HDI don't warms up fast ;) just check the instant consumption on cold mornings  :o
