Hi all, wonder if anyone can help me with a clicking type noise coming from under ze xsara.
This noise seems to happen once per wheel rotation. Only with the front right wheel. At high speed the steering wheel vibrates but the clicking noise is not so audible although is still there. At low speeds the clicking is louder and becomes more of a clunking noise. This is worse when turning the steering wheel left or right and also rolling off full lock.
There?s nothing catching on the wheels anywhere. No loose bolts or stones etc. I got underneath the car and while spinning that wheel tracked the noise down to what I think is the driveshaft? Working from the wheel inwards, the pole that the wheel hub is attached to, its the first joint that you meet. It?s a rubber gaited joint which I?m guessing is full of bearings in a cage. There is no visible damage to this, no leaks or splits. I?m guessing things have slipped or worn inside. I also want to throw CV joint in there as a possibility?
Appreciate any advice. Cheers.
